Results 1 to 2 of 2
    26th June 2016
    89
    Default Heater controls siezed
    Hi all.
    My corsa has been sat around for some time, gathering rust on the drive way.
    I fired it up and tried to turn the heating controls on. The temperature control works fine, although the control that distributes the air doesn’t seem to work. It just seems to keep turning and only comes out on one setting.
    Is this normal? I’ve looked and some people have said take the radio out?
    Has anyone else experienced this?
    15th January 2014
    644
    Quote Originally Posted by VXR Andrew View Post
    Hi all.
    Does it only work on the highest setting or something?
    Sounds like the Heater Resistor if I'm not mistaken, pretty easy fix if it is I think, sure they're about £15 from VX or thereabouts.
