Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    15th January 2014
    550
    Quote Originally Posted by baillie89 View Post
    I know the whistle you're talking about but I only noticed that after I had an uprated recirc valve added
    Same here, I get a slight whistle but it only occurred after the forge recirc was added.
  2. #12
    11th June 2016
    166
    You think instead of a filter a pre cat delete will be a better option! I have a cobra non res cat back system at the moment
  3. #13
    15th January 2014
    550
    Quote Originally Posted by BAKER147 View Post
    a pre-cat delete is a better mod than a filter, will give you a slight power increase (although you'd need a map to get the most from it) and will make the exhaust sound a little better too with that cat back
  4. #14
    11th June 2016
    166
    Do you know if a pre cat delete fits a burg? Is it the same? Just when I search eBay it states up to year 2010 and am confused lol
  5. #15
    VXRacing ahead iamphil's Avatar
    9th January 2017
    540
    You won't have a pre cat (a16), you'll have a main cat and a post cat. Only the z16 has a pre cat.
    Silver Lightning Corsa VXR
  6. #16
    11th June 2016
    166
    Okay mate could you point me in the right direction of what I neeed currently have a cobra non res cat back
  7. #17
    9th January 2017
    540
    You need something like this, if you're leaving the main cat in place you only need the 2nd longer pipe.
  8. #18
    11th June 2016
    166
    Aww so on this engine the main cat is just below the turbo. Then a cat in the long pipe then my system is back from there nice one thanks mate
  9. #19
    21st December 2017
    55
    I just got the AEM cone and driven on the motorway from Kent with it......sounded nice when I could hear it over the sound of the new exhaust haha
  10. #20
    11th June 2016
    166
    My panel filter sounds great. Surprised actually but don’t want a cone just yet lol. And as for the exhaust a custom option may be cheaper you think?
