Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
  1. #21
    9th June 2015
    386
    Quote Originally Posted by RustyPleco View Post
    Well my clutch went last night qhile i was having fun in the snow. Dont really knoq what to do now, what clutch to go for, i cant really afford to do flywheel aswell.
    If you do replace both you should do the slave cylinder as well, that will need doing.
    The problem I had with my flywheel was that it was all blocked up with dust from the clutch so wasn't working efficiently.
  2. #22
    VXR newbie R33EVV's Avatar
    2nd April 2017
    2
    Hi guys.
    Hi there I’m new 2 all this but I have a problem. I own a corsa d vxr, was driving along today and noticed a smell of oil in the car also when coming off the revs a lot of blue smoke behind me. I understand this could be many things. But further inspection has came down to this, this may sound weird but when the car is running (idling) there is no smoke/misfire or anything unusual,when you pull the oil filler cap off it smokes like mad, blue smoke and smells of burning oil and tries to suck the oil cap back on? It should try and push it away rather than suck surely? Can anybody help?
    Thanks guys
  3. #23
    11th July 2017
    326
    crankcase breather system has stopped working... find it and clean it out... maybe a breather hose has collapsed shut.... either way sort it quickly as its doing damage bit by bit to oil seals and piston rings
  4. #24
    17th September 2011
    932
    And put your question on the right forum rather than just hijacking a random thread
  5. #25
    9th June 2015
    386
    Ooft Dalle, straight in for the kill there. Sniper!
  6. #26
    1st August 2016
    340
    Must be a facebooker
    Vectra VXR estate 07
