Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    14th January 2018
    19
    Default Burning smell - possible clutch?
    Hello all,
    Have a burning smell under hard pull of or dipping the clutch when reversing, does this mean my clutch is Going?
    I'm pretty sure the smell is the clutch, anyone got any insight?
    The clutch in itself feels fine and I don't have and slipping once it's in gear, the biting point is not far off fully pressed in pedal.
    Sent from my SM-G955F using Tapatalk
    VXR enough dvinell's Avatar
    9th September 2006
    1,038
    Could also be an oil leak onto the clutch surface.
    14th January 2018
    19
    How and where would I be able to check This? Thanks
    11th July 2017
    326
    bite point doesnt tell you much about clutch wear with an hydraulic clutch and from what i see yours could be a clutch slave leaking if the bite point is that close to the floor.
    14th January 2018
    19
    Is this a big deal? Would it be expensive to have it fixed?
    3rd September 2015
    394
    Clutch Slave is not that expensive. but I am not sure where it sits on siggy and if it is easy to access.
    Anyway I would not drive to much and get the car to a garage quickly.
    If it leaks it might damage other things...
    11th July 2017
    326
    if its the slave you may as well do the clutch at the same time.... looking close to the wrong side of £1000. Massive pain to get the gearbox out
    17th September 2011
    935
    You need to remove the transmission to get at it, so as genman wrote, you might as well replace the clutch as the main cost will be labour. You can also choose to get an uprated unit as the standard clutch isn’t really strong enough for the car.
    14th January 2018
    19
    Ok I'm going to get it done, where can I find a updated clutch? Should I whack a new flywheel on at same time?
    11th July 2017
    326
    Quote Originally Posted by RustyPleco View Post
    Sachs or a custom clutch made by a specialist...fairly stock size 250mm ...think its 13 splines...used by quite a few other cars other than VXR
    Also if uprating the clutch , get the uprated slave as the clutch springs are a bit stronger ..i understand only Sachs make it
