Results 11 to 20 of 21
  1. #11
    6th August 2017
    5
    Seems to run absolutely fine, not lumpy or anything, just burns oil and mixing the fuel with oil? Cars only on 68k
  2. #12
    11th January 2006
    2,268
    It's possible then. But impossible to say without checking it.
    Even mapped "safe" it's not guarentee'd. P4 is caused when the car is mapped on the factory injectors which are insufficient to flow the fuel necessary at 5500k and above. This causes the deterioration to p4.
    not always mine was safely mapped to stage 3 on standard injectors and it wasn't running lean and even after 47000 miles of abuse no piston 4 problems
  3. #13
    17,580
    Quote Originally Posted by timmee View Post
    It's not about running lean in general. Just at the higher rpm. Of course there are always exceptions.
  4. #14
    23rd May 2013
    2,412
    More than a few exceptions - plenty of people running about mapped on standard injectors without problems, including myself.
    In fact looking back a few years nobody on here thought twice about mapping on standard injectors before the whole "maxing out" scare stories appeared.
    Not that they are complete lies, its just that the majority of people seem to skip on trying to understand the theory/implications behind it subscribe to thew generalization that "mapping on standard injectors is unsafe" like sheep.
  5. #15
    17,580
    Personally I'd rather not just ignore it and run the gauntlet though. That's just stupid.
  6. #16
    23rd May 2013
    2,412
    Ignore what?
  7. #17
    17,580
    Ignore the injector thing.
  8. #18
    23rd May 2013
    2,412
    You're really just proving my point about people generalising the problem.
    Perfectly possible to safely map to stage 3 on standard injectors and has been proven many times, can't deny that.
    If you speak to EDS they'll tell you standard injectors as satisfactory.
    If you speak to Courtenay they tell you similar - if fact first line on their website "if these injectors are in good flowing condition the engine is capable of running at Stage 3 which for us is power normally around the mid 230’s".
    As far as i'm concerned if your car has gone bang on standard injectors its either your own fault (not exercising proper care, changing the car from where it was mapped at etc), or your mapper has cocked up badly.
    TBH if they're cocked up that badly they'd also have done this on uprated injectors....the only difference is with the uprated injectors there probably a bit more leeway (i.e. fuel to add cooling) for them to hide mistakes and get away with a bad map.
  9. #19
    VXRacing ahead Tom{BSc}'s Avatar
    29th January 2011
    585
    I've not read the whole post but it sounds similar to the problem I had. Slightly bent rod in cylinder 1. Compression test came out slightly lower - but if your cylinder has oil sitting in the bottom it may still be holding the pressure.
    I done a wet compression test to rule out valve problems - they all came back with good pressures.
    Get a small camera in to look at the bore. That's what I did. Bore had scoring in it and it was sent to WG Motorworks for forging. I have the banana rod and scored piston as a souvenir.
    I hope that helps?
  10. #20
    6th August 2017
    5
    I’ve just spoke to the garage and they’ve came back saying that it could either be valve stem seals or the piston rings have seized, but it’s finding out which one it is ��
