Results 1 to 7 of 7
Thread: Brake disc's
    10th January 2015
    451
    Default Brake disc's
    Just had front brakes skimmed today using pro=cut machine very impressed with the finish and fitted new pads £65+vat for the skimming.
    15th July 2008
    88
    Angry
    Hi,
    Can you tell me the mileage on your car when you had your brakes skimmed.
    I have phoned a garage with a pro-cut brake skimming machine and was told that with 32000mls on the clock I would need new discs rather than a brake disc skim!
    All I said was that I had steering wheel judder when braking.
    He said the machine takes a minimum cut of 0.4mm(16 thou of an inch) each side.
    He also said this would take the disc side down to unacceptable thickness levels!
    I am a engineer who on many occasions have machined brake discs a plenty,
    As I have not the equipment at my disposal to do the job myself I have to go elsewhere.
    The car was bought from new and has not had any skimming done before.
    Is this person talking a complete load of Boll**ks.
    What is the minimum thickness of the front brake discs?
    Many thanks
    Rich
    VXRed moorie's Avatar
    22nd February 2006
    195
    I believe the minimum thickness is 30.0 mm
    VXRed blooded Klystron's Avatar
    2nd June 2015
    483
    I had my discs changed at 29k miles, and there was 1mm of wear on each side. they are 32mm disks and I found somewhere that the limit was 30mm.
    15th July 2008
    88
    Has anyone used Mtec discs? These seem to be the cheaper option to OE .
    They also look the business.
    22nd February 2006
    195
    I'm about to buy and fit some maybe this week!
    10th January 2015
    451
    These disc's have done about 20 thousand miles as they were replaced before under warranty. The limit is 30mm I had them skimmed because I was fitting new pads and did not like the lip on the outer edge .
