Results 1 to 10 of 11
    4th July 2017
    4
    Angry Intercooler Problem
    Intercooler Problem
    My Astra H Vxr is completley standard no aftermarket upgrades at all, after a long journey the other day i noticed steam coming from my engine bay, pulled over and it appears water is leaking from somewhere and getting onto the hot pipes. After letting the engine cool down i noticed it had lost alot of water so topped it up and let it sit for a while, no water leaked but 10 mins into my next journey and the problem returned. It appears my intercooler has a hole in it (somehow) and although it doesnt appear to be the direct source of the leak, no doubt this will be causing problems. My question is should i replace this intercooler for another standard one, or should i go full Airtech FMIC and remove the old standard unit if not needed? Please Help!
    6th February 2008
    15,949
    Are you sure it is the intercooler, as this only has air in it
    Probably it is the radiator, and require replacing it is leaking and you are using coolant
    4th July 2017
    4
    I wasnt 100% sure which is intercooler and which is rad, searched vxr intercoolers and looks the same as mine with hole in so assumed its that. The coolant is droppin onto the belt to the left of the engine causing it to spray once it gets hot, hope this narrows.
    18th September 2017
    480
    Sounds like it’s radiator as if it’s completely standard you won’t be running an intercooler
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
    VXR enough Ant21's Avatar
    29th September 2013
    1,454
    Standard vxr’s do run an intercooler ^
    Anyway, it’s your radiator that’s damaged. There are 3 coolers in the front of all vxr’s and they are in this order from front to back...
    AC condenser
    Intercooler
    Radiator
    I would check all pipes first to ensure they are not split and if they are good then go about replacing the radiator.
    4th July 2017
    4
    Thanks for reply Ant21, your knowledge and help is greatly appreciated. Il get to work at weekend to find the cause of the issue now im abit more clued up, will post update on here.
    29th September 2013
    1,454
    No problem. Just do not let it run out of coolant!!
    16,627
    AC condenser
    Intercooler
    Radiator
    If you can call the standard one an intercooler lol. The way it's tucked behind the radiator makes it virtually pointless.
    15th May 2013
    17,877
    Agreed. It's tiny too. FMIC is a good thing to add to these
    16,627
    An example of cost saving from various. Using the same kinda setup as in the cdti
