Results 1 to 10 of 11
    VXRed blooded Arron D's Avatar
    9th February 2018
    367
    Default Lights not working
    I purchased these from ebay
    https://www.ebay.co.uk/itm/VAUXHALL-...cAAOSw05tahEIy
    ive fitted these and they don't seem to work , does any1 know a reason why not ? I can only get one to work while old bulb in other side , if new bulb in both then one of them flickers while other doesn't work , ive tried changing bulbs round but still no joy, when I unlock the car both new Reg plate bulbs come on but then go off when turn actual lights on
    9th January 2017
    815
    Link doesn't work but I'm presuming the lights are not compatible with canbus.
    Silver Lightning Corsa VXR
    9th February 2018
    367
    Dunno why link won't work I'll try again https://m.ebay.co.uk/itm/VAUXHALL-CO...cAAOSw05tahEIy
    It says error free, Cambus compatible etc the lights worked when I unlocked the car but when engine on they didn't work, could my aftermarket stereo be the problem?
    6th May 2017
    695
    Could try putting the original bulbs back to see if the new ones are the issue or it's something else.
    9th February 2018
    367
    I have put old ones in and they work, new ones work only when unlock car with fob then they go off :headscratch:
    6th May 2017
    695
    Are these reg bulbs or dipped, drl etc?
    9th February 2018
    367
    Reg bulbs I think mate, I've fixed the link and it says this VAUXHALL CORSA D 04-10 Canbus ERROR FREE Number Reg Plate Bulb 19LED 6000k White
    6th May 2017
    695
    I think that some led bulbs are not compatible, even though they are sold as canbus error free. If you can return them, it would be worth trying a different type.
    I know W20ADM on here sells reg LEDs, if you drop him a DM, I'm sure he will have some that will work.
    9th February 2018
    367
    Thanks very much I gave them bulbs to friend and have just payed Adam on here for his, thankyou for the advice
    6th May 2017
    695
    Hope you get it sorted.
