Results 11 to 20 of 22
  1. #11
    VXRed Jamescorsa's Avatar
    18th September 2016
    31
    I re-used the bolts. Just gave them a quick wire brush before taking them off. 16NM for the bell bolts
  2. #12
    VXRed moorie's Avatar
    22nd February 2006
    195
    Thanks mate !
  3. #13
    VXRed TimothyGideons's Avatar
    3rd August 2014
    112
    How much did you pay for these?
  4. #14
    18th September 2016
    31
    Quote Originally Posted by TimothyGideons View Post
    £140 pads
    £305 discs
  5. #15
    15th July 2008
    88
    I have just received my new front discs from mtec.
    Looking at the brake calipers the bolts that hold them on seem to be of a torque fitting?
    Can anyone on here confirm that a normal hexagon socket will loosen the bolt or do I need a torque spanner/socket.
    Hope to change them very soon as the wheel wobble when braking is so bad .
    I cannot believe that I have needed to change the discs at 33000mls.
    I have never driven the car hard or braked very suddenly.
    What I find very strange is the fact when I checked for disc run out with a dial test indicator the measurement is less than .002 total reading.
    One other strange thing is, when I put all the brake pads back in after this diagnosis the brake judder is fine for about a day, then it comes back with a vengeance!
    Overall, the problem links this to warped discs but the DTI tells me different.
    Totally weird!
    Very frustrated
    Rich
  6. #16
    VXRed amonkey's Avatar
    16th August 2012
    52
    Default New front brakes
    I am looking for the mtec rotors too.
    Warren is offering a disc for the rear in the same J hook style, so i will order a pair for the front snd rear.
  7. #17
    3rd August 2014
    112
    thanx mate, where did you purchase them from?
  8. #18
    11th July 2017
    332
  9. #19
    12th July 2012
    151
    Default discs
    Quote Originally Posted by richiegsi View Post
    Totally weird!
    Very frustrated
    Rich
    hi had same problem if you leave your foot on the brake after braking sitting at traffic lights you get a pad imprints on brake discs.
    all you need to do is give discs a good rub down with emery paper job done
  10. #20
    3rd May 2014
    24
    Quote Originally Posted by Jamescorsa View Post
    £140 pads
    £305 discs
    I bought the groved discs from Mtec last year, was £300 per disc. I had to re-drill the holes for the bell bolts as they were too small, they forgot to allow for the shim at the top of the bolt, guess yours were ok? They must realized the mistake and sorted it for future discs. I got the pads from Courtney Sports, HP2000, £150
