Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    6th April 2017
    77
    Quote Originally Posted by bembo449 View Post
    anyone know how much the pump is to replace then?
    Around £800 for pump replacement, haldex oil and labour charge, which I would suggest every 4yrs/40k.
    I would also suggest changing the haldex oil every 2yrs/20k.
    Insignia Elite 2.8T (2012), Viva SE-AC (2017).
  2. #12
    VXR enough AJG's Avatar
    10th January 2010
    1,305
    Quote Originally Posted by El1te View Post
    It really only needs the filter and fluid changed. The pump fails when the filter becomes blocked.
    http://www.vxronline.co.uk/forum/sho...x-Holy-Trinity
  3. #13
    6th April 2017
    77
    Quote Originally Posted by AJG View Post
    You're probably right about not needing to change the pump but since (engine) water pumps and oil pumps are often recommended to be changed around 6yrs/60k it makes sense to consider changing the haldex pump once in the lifetime of the car 'just in case' because of the expensive consequences and the risk of no advance warning (unlike a failing oil or water pump which often give warning signs and dash error messages).
  4. #14
    9th August 2011
    2,464
    well I test drove a white saloon on a 10 plate on Saturday morning , had receipts for most of the important stuff like , haldex repair 5k ago , stuck it in vxr mode and guess what , "bing" rear axle fault came up , was so brassed off so im hoping its not going to be a common theme on every one I drive
