Results 1 to 8 of 8
    5th March 2018
    11
    Default Zafira vxr oil leak
    Hi all just wondered if anyones got any idea about the oil leak Iíve got seems to be on the right hand side of the rocker cover Iíve tried with 2 or 3 new gaskets and had cam shaft seals done but still the same any help would be great will try get some better pics in daylight tomorrow.
    Thanks in advance
    Roy
    5th March 2018
    11
    Added extra picture
    Oil seems to be leaking down onto gear box any help or ideas of where it’s coming from would be great.
    Please help me!!!
    22nd April 2017
    53
    You need to clean it all off with de greaser first, then spray some chalk spray around the area. That will show you where your leak is
    5th March 2018
    11
    Thanks Carlmu
    Didn’t think of that will give it a go later cheers mate
    VXR enough britishbeef's Avatar
    11th October 2006
    3,189
    are you using sealant with the gasket also what did you torque the rocker to
    5th March 2018
    11
    Hi britishbeef yeah sealant always used but not to sure about the torque due to local garage doing the work!! What’s recommended torque wise?
    VXRed blooded tye_time's Avatar
    24th February 2017
    475
    Quote Originally Posted by Roy100 View Post
    torque for rocker cover bolts is 8nm - here is a great how to video:
    https://youtu.be/uiADKym2Gh0
    5th March 2018
    11
    Thanks for that does anyone know if you can get an upgraded gasket for the rocker cover or is just an original Vauxhall?
