Results 1 to 3 of 3
    7th March 2018
    18
    Default Haldex service parts
    Hello everyone!
    I am new on this forum and would like your opinion.
    I have recently made the service on the Haldex Clutch (oils and a filter). The car has done 48.000 km or a little over 30.000 miles. The mechanic at the Opel dealer said the oil looked fine, "just a little bit murky". I suppose he meant it was fine.
    I have seen here a post about service part numbers from 2015. The thread was closed so I am opening a new thread.
    You mention here following part numbers:
    20986573 - £55.80 Inc
    93165387 - £92.40 Inc
    93165290 - £18.84 Inc
    On my invoice the first two items are the same, but instead of 93165290 I can read 93165383. And the price was double, while other 2 items have similar prices.
    Also the Saab central mentions:
    93165387 clutch fluid
    93165383 transmission/transfer case fluid
    88862624 differential fluid (a 3rd fluid)
    I would like to know do we need to change 2 or 3 different fluids. Also in my case they have used about 0,3 litres of 93165387 and about 0,6 litres of 93165383. Are those quantities adequate?
    Thank you for any answer.
    Bardo
    Insignia ST OPC Unlimited
    2016
    11th July 2017
    328
    290 is for the gearbox... 383 is for the transfer box... wouldnt expect to need 290 so looks to me like your mechanic used the correct fluids.
    2 needed for the rear axle and diff and 1 for the transfer box.... rare for anyone to even check the transfer box.
    7th March 2018
    18
    Thanks Genman! Sorry for the late reply. Then everything seems to be alright. I would really like to cherish this one, considering that latest developments with Opel/Vauxhall.
    Sent from my SM-N950F using Tapatalk
    Bardo
    2016
