Results 11 to 20 of 29
  1. #11
    10th June 2015
    143
    You are right it doesn't need to be taken out.
  2. #12
    2nd April 2015
    342
    Quote Originally Posted by d fry View Post
    Nice one. Might be a quick 1 day job for the bloke. How much are the diff bearing kits?
    Astra H VXR | Stage 3 | 304 Bhp | Whiteline RARB | AEM cone filter | Direct Route | Airtec front mount intercooler | Cobra Sport 3" Exhaust non-resonated + Sports cat
  3. #13
    VXR enough Ant21's Avatar
    29th September 2013
    1,507
    The gearbox doesn't need to be taken out to do the main bearings either.
    To be honest, I wouldn't waste your time / money on replacing the diff bearings. I've never really heard of these going. If it is your box, it will be the usual suspect bearings. If that's the case, I'd suggest making the effort to go and visit a specialist. Either WG, Halifax Gearboxes or AS Autocare. These guys are the only 3 you'll really hear about on these forums that have any true experience dealing with the infamous M32.
  4. #14
    15th May 2013
    17,929
    Halifax are where you want to go based on your location
  5. #15
    22nd April 2017
    73
    Before you depress yourself even more, just jack up the wheel and turn it. If you put your hand on the shock absorber when turning and you can feel a roughness, then it’s a wheel bearing. It’s a nice quick and easy test.
  6. #16
    9th January 2017
    822
    AS autocare are a complete waste of time, I called into them when I thought I had a noisy gearbox bearing and the guy on the reception desks advise was to sell the car even though I'd only just bought it. Turned out to be the nsf wheel bearing anyway.
    Silver Lightning Corsa VXR
  7. #17
    2nd April 2015
    342
    Nice one mate. Totally forgot about those guys. Definately better than driving down to London for WG
    Has anyone heard of Austrin Gearbox Specialists in Newcastle. These guys have said they've done lots of M32 gearboxes but i've never heard them mentioned.
  8. #18
    22nd April 2017
    73
    Have you checked your wheel bearing yet?? Could just be a simple fix
  9. #19
    2nd April 2015
    342
    Quote Originally Posted by Carlmu View Post
    Not yet. It's been ****** weather. No way to do it without getting soaked. Should I be hearing some kind of noise like grinding to go with the rough feeling on the shock?
  10. #20
    20th January 2014
    2,163
    Passenger front whining is usually the missus ....
    Hitting the ejaculate button like Knight Rider usually get rid of them.
    @OP; if you'veno time to jack off, after a spin, feel each alloy up front. Dry bearing may create enough friction to generate a noticeable accumulation in heat on a single side
