Results 1 to 9 of 9
    VXRed Vxr..'s Avatar
    1st March 2018
    190
    Default New brakes smoking
    Got new disks and pads under warranty
    Went from York to crown point in Leeds had to pull over because they stunk and we’re smoking ???
    11th July 2017
    342
    likely not had all the storage preservation coating removed before fitment....will burn off eventually but the pads could be contaminated and need replaced as the coating is a form of oil
    1st March 2018
    190
    Ahhh right.
    18th February 2007
    51,649
    Driving hard on new brakes or bedding them in and allowing some heat cycles before you go for glory?
    Astra
    1st March 2018
    190
    If I was driving hard it would make sense but I wasn’t it was raining so was a chill drive for some food
    20th January 2014
    2,163
    Now if they're EBC pads with their "brake-in" coating that's like sandpaper, you need to be extremely gentle with them for the first 200 miles or so.
    Worst case scenario; sticking calipers.
    Most likely as above though; the anti-corrosion layer oil is burning off when braking.
    OPC ÉIRE- Drop me a PM for Irish meets, group adds etc.
    1st March 2018
    190
    There just standerd brakes as it’s waranty
    20th January 2014
    2,163
    Warranty from where though? Even EBC supply economy pads
    1st March 2018
    190
    Autofirst in York part of Autopoint we’re I got the car
    There ok now I’ve done a few miles
