Results 1 to 10 of 13
Thread: Error codes
    VXRacing ahead
    5th March 2016
    740
    Default Error codes
    Went for a drive today with test meter connected all good no error codes temperature all good and intake temperature good with my air Tec doing its job but when I first connect the OBD reader the top 2 codes say fail but when I go to read codes it says they have all passed, any idea
    23rd May 2013
    2,340
    Thats not error codes though.
    I think thats just the protocols the reader is attempting to use to connect to the ECU...as its generic reader its probably trying some method the corsa doesn't understand, then retries again with another (e.g. CAN/Controller Area Network) until it gets into the ecu.
    Its a bit like trying to open a door with a big bunch of keys...it'll just try them all until it finds one to get into the computer.
    VXRacing ahead
    5th March 2016
    740
    Ok cheers for that least it means my car is ok , the Airtec intercooler works well as on a fast run the intake temperature went up to 29 degrees which I think is good
    VXR enough Jon1796's Avatar
    24th August 2015
    1,316
    If you’ve got a few ££ spare try the mdi with t2win or the t3 software depending on what year your on.
    VXRacing ahead
    5th March 2016
    740
    Never heard of them how much will it cost
    24th August 2015
    1,316
    VXRacing ahead
    5th March 2016
    740
    The second is a bit pricey , is the first just the software you put on a laptop?
    24th August 2015
    1,316
    First is t2win which is tech2 on Lappy but you need mdi to use it but with mdi you get gds which is the tech3 software depending on what year yours is.
    VXRacing ahead
    5th March 2016
    740
    Mine is a 2011
    23rd May 2013
    2,340
    That Tech2Win is only on version 127 though.
    It might be fine for the vectra but i don't think it will cover the corsa d, or at least not the later cars like his.
    i.e i have a physical tech 2 which is on version 172 iirc and that doesn't seem to cover the late model cars fully.
    Presumably you'd need to get an updated BIN file from somewhere to be able to do anything Corsa wise with that tech2win
