Results 1 to 4 of 4
    15th January 2014
    646
    Default Steering Wheel Controls / VXR Panel
    Hi All,
    Can anyone tell me how to remove the steering wheel controls for radio etc. from the steering wheel?
    I'm assuming if I remove the airbag, i can access it from there but thought I'd check?
    Also how to remove the silver panel at the bottom where the VXR badge sits?
    Got some leftover alcantara wrap from a friend and going to give a little bash at wrapping these to see how it goes.
    9th January 2017
    795
    Quote Originally Posted by Brucerutherford View Post
    Hi All,
    Pretty sure they are removed by brute force (no screws), I would like to remove mine for wrapping but I'm scared of breaking them
    Silver Lightning Corsa VXR
    VXRed Neil84's Avatar
    31st March 2014
    14
    Not sure about controls but I know 100% the silver part at the bottom just pulls off. It's held in by two plastic plugs that just slot into the wheel. No screws, glue or clips. Yank it from the bottom and work your way round.
    15th January 2014
    646
    Got the silver bit off, cheers guys.
    Also managed to find with a bit of digging the controls parts are definitely just by force too, if it helps anyone
    Althought they won't come past the airbag very easy so I'm going to get the battery disconnected and just remove the air bag to do those parts to make it a bit easier.
