Results 1 to 10 of 12
Thread: Rubber care
    VXRed Vxr..'s Avatar
    1st March 2018
    189
    Default Rubber care
    Whatís the best rubber care for the rubbers around the windows etc
    And to get them clean
    20th March 2015
    360
    I use the Autoglym Vinyl and Rubber Care stuff - been using it for years and always had good results
    17,637
    2 words
    Carpro perl
    Nuff said
    15th May 2013
    17,909
    Apparently that Gummy phlege stuff it the one 👍🏼
    VXR enough Ant21's Avatar
    29th September 2013
    1,492
    As above. Gummi pflege made by nextzett. I use it and it’s brilliant plus it’s water based
    17,637
    Carpro perl is water based, and it's awesome value for money cause you can use it neat for heavy applications but can be diluted down several times for most regular rubber and plastic applications.
    30th January 2016
    329
    Iíve used a lot of products on a lot of cars and hands down auto finesse revive is the best Iíve seen for window trims, rubbers etc, it dries in with a satin finish and stays on wash after wash, other stuff, Iíve found, either runs off in heavy rain and causes streaks down the car or it washes off all together!
    18th February 2018
    200
    Quote Originally Posted by 20Drift View Post
    Thats what i brought from amazon also. Havent used it yet but im hoping i will get good results. How did you apply it?
    17,637
    If you want a true long lasting coating gtechniq is the way to go. Semi permanent
    1st March 2018
    189
    Quote Originally Posted by VXRer View Post
    Autogym is rubbish
