Results 1 to 6 of 6
    VXRed blooded srea064's Avatar
    22nd September 2015
    369
    Default Will a Corsa E VXR wheels fit a Corsa D VXR?
    As above please, my Corsa D VXR wheels are constantly leaking around the tyre bead and it seems the Cora E VXR wheels are cheaper.
    Will I have any problems with TPMS, or whatever system a 60 plate D VXR has fitted?
    Thank you in advance.
    *** Cavalier MK3 SRi 130 > Astra J SRi 2.0 CDTi 160 VX Line and a Corsa D VXR > GTC SRi 1.6T 180 VX Line > Astra GTC VXR 280 > Focus MK3 ST3 250 > Focus MK3 RS and a Corsa E VXR ***
    31st December 2014
    1,576
    If im not mistaken they are the exact same wheels buddy.
    VXRed blooded GREGOR92's Avatar
    19th December 2012
    448
    Should fit although the profile is slightly smaller on the e being 215/40/18. The same alloys on the d come with 225/35/18. Dunno why they changed the size.
    Corsa VXR Nürburgring 280 - Gone!
    Corsa E VXR flash blue,performance pack + toys - Gone!
    Golf R 7.5 indium grey, Black Pretorias +toys -oh yeah!
    31st December 2014
    1,576
    Quote Originally Posted by GREGOR92 View Post
    Didnt know they changed the size. Bit strange c9nsidering its basically the same car 😂😂
    Regional Assistant - West Midlands TheMadHouse's Avatar
    9th November 2009
    4,387
    Quote Originally Posted by Desert_Cloak View Post
    Corsa E and Corsa D Diamond Cut Alloys are slightly different. The Corsa D version does not clear the Brembo Calipers used on the Performance Pack. Not sure on Corsa E wheels onto a Corsa D but same PCD and stud pattern.
    West Midlands Northern Area R.A
    22nd September 2015
    369
    Thank you for your replies, much appreciated.
    Does anyone know if the tyre pressure monitoring, DDS as it’s known as on my 60, changed between models?
