Page 3 of 13 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 130
Thread: rocker painting
  1. #21
    14,707
    Quote Originally Posted by kopite81 View Post
    What you doing with the spark plug cover?
    Nothing mate. It's gloss black so will just suit the theme as it is.
  2. #22
    14,707
    Maybe get a new unscratched one
  3. #23
    VXRacing ahead kopite81's Avatar
    9th December 2014
    680
    £15 makes sense
  4. #24
    14,707
    Quite pleased with this tbh !!!
  5. #25
    9th December 2014
    680
    Looks good, Get it in airing cupboard for 24hrs to cure before clear coat
  6. #26
    VXR enough chodiddly's Avatar
    12th December 2015
    1,542
    yeh that looks sweet mate i like it
    did u not cover the underneath of the rocker cover with anything?or does that not matter?
  7. #27
    14,707
    Quote Originally Posted by chodiddly View Post
    Ultimately it doesn't matter bud. Barely anything gets underneath anyway, cause you spray from top down
    The flattened cardboard box it sits on generally stops 95% of spray from underneath.
  8. #28
    12th December 2015
    1,542
    ah right ok cos im gna have a go at mine in the next few days have u got any tips lol
    so once uve sanded down sprayed primer to it a few times n sanded down then spray with gloss black a few times? is that it then just leave it to dry?
  9. #29
    14,707
    I used scotchbrite pads to scuff up the surface for the primer to cling to.
    Just be sure to wipe down the surface with ipa or rubbing alcohol before each paint layer to remove all traces of oil and finger grease. Also helps to rub down with a tack cloth to remove any dust that's managed to settle on the surface after wiping with ipa too for each step.
    Remember to add a layer of clearcoat after to protect the finish, and for the ultimate shine you can get the polisher on it once it's cured
  10. #30
    12th December 2015
    1,542
    ah ok mate thanks
    with the clear coat is it THAT that makes it really glossy and shiny?
