Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 79
  1. #11
    Are you VXR enough?
    5th March 2016
    851
    Quote Originally Posted by craigybaby View Post
    Off the top of my head I think they are Ngk bkr6eix
    Put new plugs in , the correct Vauxhall ones and although a bit better still not right , will try get it in garage for compression check in the week , if it passes that any ideas as itís peeing me off as spent a small fortune on car so far with massive brakes and wavetrac diff and gearbox upgrade new wheels etc
  2. #12
    23rd May 2013
    2,414
    Just buy the gauge, they're only about £20
  3. #13
    Are you VXR enough?
    5th March 2016
    851
    Whatís the pressure reading of a good engine? Compared to one with a piston or rings fault
  4. #14
    VXR enough yodacraig's Avatar
    25th January 2010
    3,059
    Readings should be equal across all cylinders when u test it if one is significantly lower than the rest thats your issue
    xbox addy -turboyoda85
    Instagram yoda_craig85
  5. #15
    Are you VXR enough?
    5th March 2016
    851
    Ok just wanted a rough reading what a really good engine should be as I could have all the same readings but engine could be knackered
  6. #16
    23rd May 2013
    2,414
    Ideally about ~ 175 PSI across all cylinders.
  7. #17
    VXRed Neil84's Avatar
    31st March 2014
    16
    I had the same issues for a week. Bought a compression test kit that read 170 across all 4 pistons. Cleaned MAF and MAP sensors, reset ECU, changed plugs and coilpack.
    Ended up been a case of dodgy Shell Optimax. Ran it to the red light and filled it back up with Ultimate. Problem solved.
  8. #18
    Are you VXR enough?
    5th March 2016
    851
    Quote Originally Posted by Neil84 View Post
    I will get mine checked if all ok Iím just gonna drive it till empty and try different fuel but has £50 of shell v power in at minute 😞just put another post up of pictures of OBD not sure if right or wrong
  9. #19
    31st March 2014
    16
    Quote Originally Posted by GPH69 View Post
    I will get mine checked if all ok I’m just gonna drive it till empty and try different fuel but has £50 of shell v power in at minute 😞just put another post up of pictures of OBD not sure if right or wrong
    My mistake, it was also V Power I used. My car would struggle to start, drop revs badly, sound like a bag of nails and almost cut out. After a minute of light revving it would settle and be ok to drive. I hope it's a simple fix mate
  10. #20
    Are you VXR enough?
    5th March 2016
    851
    Interesting as I previously put wasp in and it ran ok but I ran it near empty and filled to the brim with v power and went to Halifax and back around 200 mile round trip so maybe the fuel, hope so
