Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    30th January 2018
    67
    Default Noise from drivers side dash
    Hi guys,
    So yesterday just as I let off the accelerator and started to brake for the slip road there was a strange noise that sounded like it was coming from behind the dash to the right of the steering wheel.
    This noise can be described like when you have two dash panels rubbing against each other and I'm sure there was a bit of vibration through the wheel.
    I can't remember if I hit a pot hole and haven't yet checked the wheels for their weights.
    What is in the dash behind the air flow thing?
    This noise isn't constant but definitely just started yesterday.
    I think I'll try and get a video.
    Any thoughts tho?
    30th January 2018
    67
    A little update on this, it's been twice to Evans halshaw. First time they replaced the interior a pillar tri, that failed.
    So on Monday just past they took it in for the week and took the dash out, said they found a module lose. So tightened it and said that should be it done.
    Noise is at and above motor cruising speed, so would be bad on a track.
    Anyone have an idea?
    Today I've took the vent cover off, the speaker cover off and the side panel where airbag turn off is and took it for a drive and it didn't rattle but I think it might just be luck as I sounds like it's coming from behind the vent.
    Any help would be great.
    Ok,,I have a video but don't know how to upload it.
    Sorry
    VXR enough baillie89's Avatar
    18th February 2015
    1,098
    Does it sound like a squeal of some sort? .. From what you've described, I think it might be the suspension bushes.. can usually be heard from the inside and sounds like it's coming from the dash
    Stage 3 Corsa VXR- Gone!
    Octavia VRS TSI MK3
    VXR enough Jon1796's Avatar
    24th August 2015
    1,529
    On iPad just go to video, picture top right screen square with arrow in it press then copy.
    Go to Tapatalk open reply, press hold then paste. Simples !!!
    30th January 2018
    67
    Thanks I’ll try it on iPad later, although I’ve just tried it on iPhone 5s and I can’t see any arrow??
    Am I missing something here??
    24th August 2015
    1,529
    on the phone bottom left once you’re in the photo or what ever.
    30th January 2018
    67
    Yeah I've tried both, there is no copy function....
    There is duplicate which does as it says but nothing to copy.
    24th August 2015
    1,529
    On iPad just go to video picture top right screen, when you get go to more at end of line then turn on copy.
    30th January 2018
    67
    That’s all that is there,
    Looking at it I think you can copy a picture but not a video.
    30th January 2018
    67
