Results 1 to 5 of 5
    15th November 2017
    17
    Default Can anybody help - rror code 0100 (06)
    Hi guys!
    Can anybody help? I have an error code which is 0100 06, which I'm aware is MAF circuit related. I have changed the sensor, checked all of my vac lines, boost pipes etc and the code is still coming back each time after a hard reset (battery disconnect for 20 mins).
    My MAF loom has been extended, however all wires look fine and in tact. Is there anything else I can try or look out for? Really bugging me now, as my car boosts absolutely fine and then goes into a limp mode after maybe 1 mile every single time I drive it..
    Thanks in advance for any help/advice
    25th September 2013
    1,076
    you sure the extension was not mixed up the wires and joined one to the wrong one , is maf around the right way .
    stage 3
    15th November 2017
    17
    Thanks for the reply.
    The MAF extension was done when I got the car over a year ago and I've never had any issues at all until now. And yes, MAF is in correctly.
    15th November 2017
    17
    Any more thoughts on this? Problem is still present..
    Thanks in advance
    26th February 2012
    1,772
    Try cleaning the maf with electrical contact spray
