Results 1 to 4 of 4
    20th December 2017
    22
    Default Catalytic converter collapse
    I was driving home on the motorway last night and when I pulled off, the car was noticeably quieter and down on power.
    The car wasn't as slow as it is in limp mode, but it's definitely slower than usual.
    I'm fairly sure from those symptoms that the cat has collapsed - there was a horrible cat smell from the exhaust at times over the last few weeks.
    I'm going to replace both the precat and the main cat with decat pipes. Can someone confirm if these ones from eBay are correct?
    https://www.ebay.co.uk/itm/401497027622
    https://www.ebay.co.uk/itm/161963302234
    20th December 2017
    22
    After buying and fitting this the problem is solved. The centre cat appeared to have collapsed
    VXR enough R34nel's Avatar
    17th May 2009
    2,538
    You bought the 2nd decat for £663??!
    audi S3 stage 2+ Gone
    Stage 3 Arden Astra gone
    Stage 2 burg Astra gone
    standard Arden Astra current
    20th December 2017
    22
    Quote Originally Posted by R34nel View Post
    I thought it was a good deal...
    Just kidding, I actually bought this Direnza one for £140.
