Results 1 to 6 of 6
    24th January 2018
    7
    Default Astra vxr m32 gearbox problems
    Looking for some help here, car developed a whine off throttle under 2000rpm in 5th and 6th so I bought the 62mm case and bearings and took it to the garage for replacing i also said to change the rest of the bearings while there fitting the updated case, anyhow the garage has had the car 3 weeks now they say they changed all the bearings etc and took the car on a test run and it's still got noise in 5th and 6th as before, so they recommend change 5 and 6 gear sets and still the noise, there now saying maybe it's the pinion shaft and crown wheel, any 1 have the same experience as me here
    VXR enough X8 DUD's Avatar
    26th October 2012
    2,735
    Def coming from gearbox?
    24th January 2018
    7
    Update to this they said they got a diffrent gearbox as they didn't no where whine was coming from and now when I go from 3rd to 4th it's a big jump in ratios, it's like going from 3rd to 5th, doesn't stop there though 4th and 5th seams exactly the same gears any 1 no what these cowboys have done they want shutting down
    Are you VXR enough? kopite81's Avatar
    9th December 2014
    811
    Where did you take it?
    Astra H OPC - CDTi Conversion with K&N Panel Filter | Iridium NGK Plugs | Custom Rocker Cover | Various Orange hoses | CD70 / CID upgrade | Interior LEDs | BMW Mini Sport Aerial | Insignia Washers | Courtenay High Flow Plenum | Hekos | MWP S1 Remap
    24th January 2018
    7
    Leeds transmission
    9th December 2014
    811
    Quote Originally Posted by P44ttf View Post
    Leeds transmission
    Should have gone to Halifax clutch and gearbox centre pal
    Sent from my SM-G950F using Tapatalk
