Results 1 to 6 of 6
    VXRed MrHus's Avatar
    14th February 2018
    60
    Default Scraping type noise from driver side?
    I honestley dont know how to explain this but i was driving home from work and noticed this scraping noise at low speed as if something was scraping against a tyre looked under the car but couldnt spot anything...the noise is not constant but has a certain spot where it might catch on somthing checked the brakes couldnt see anything visual wrong...could it possibly be low tyre pressure or is my car too low and the tyres are scraping on the inside of the arches? Any help would be much appreciated
    VXR enough Ant21's Avatar
    29th September 2013
    1,507
    Potentially going to be your disc backing plate. They can be easily damaged or bent, making them touch the disc and make a noise.
    Crawl under and just bend it away from the disc. It's only a small piece of metal and is at a 6 o'clock position on the rear of the disc.
    14th February 2018
    60
    I will give that a go tommorow after i give the tyres a pump thanks for the reply will let u know how i get on
    29th September 2013
    1,507
    Quote Originally Posted by MrHus View Post
    No problem, hope you get it sorted
    18,147
    I had that scraping backing plate too. Took me an absolute age to find. Did my head in lol
    14th February 2018
    60
    Just a quick update i did try bringing the guard back a little with no success so i went to a petrol station and the tyre in question was on 28psi and all the others wer 30 so i put them all on 33 and wollah no noise and a perfect ride!!
