Results 1 to 5 of 5
Thread: Elm 327 obd2
    31st December 2014
    1,576
    Default Elm 327 obd2
    Anybody used this before?
    Seen a video online and looks pretty good for £4
    11th July 2017
    332
    some work fine but can mess with the cars can communication if left plugged in all the time.. messed up a Jaguar XF i had but haven't tried it on the vxr
    31st December 2014
    1,576
    Dont really intend on keeping it plugged in, really only buying to check that things are running right and theres no codes hidden that havnt popped up 😁
    VXR enough chodiddly's Avatar
    12th December 2015
    1,647
    Quote Originally Posted by Desert_Cloak View Post
    ive got the elm 327 but doesnt seem to have a setting for vauxhall so i put it in my drawer and left it alone lol
    seems it cleared a fault code that came up but didnt give me the info on the fault lol
    Im not sure wether i needed to look into it a bit more but i didnt really trust the figures it was showing.
    maybe somebody else has had some luck with it
    31st December 2014
    1,576
    Recieved it today, plugged in and purchased the Pro app because it has more settings and is more accurate.
    Initial thoughts:
    Its pretty impressive for the price, now whilst i cant comment on how well it works on EML light (have no codes).
    I set up a car profile as accurately as i could to my Corsa.
    Boost was reading 13psi which i believe is right?
    Engine coolant temperature was spot on (checked under the secret menu)
    It had a BHP setting on it so going to try that out aswell.
