Results 1 to 6 of 6
    VXRed ash121186's Avatar
    30th June 2014
    194
    Default retro fitting bluetooth
    I just bought a factry Bluetooth kit to retro fit to my Astra h vxr. the kit I got is the one you got to solder/connect the wires to my radio loom but is there a way i could put a plug on the end on my Bluetooth loom so it's a plug and play loom so I haven't got to chop into my car loom. or can i buy some sort of loom extension what plugs into my cd70 and then plugs in to the car radio loom so i can chop into the extension part of the loom instead and 2nd question is the wire for the Mic on the Bluetooth loom hasn't got a plug on the end to connect to the Mic do any one know what type of plug I needs thanks
    Sent from my SM-G950F using Tapatalk
    17,667
    Where'd the kit come from mate? Only place I could find was from pecky but he doesn't do them anymore.
    17,667
    This was the kits pecky used to make. If you look at it you can see the adapter looms to totally avoid soldering!
    30th June 2014
    194
    I got it of eBay but now I got a plug and play loom like the one perky does.
    17,667
    Quote Originally Posted by ash121186 View Post
    Where from mate?
    Are you VXR enough? kopite81's Avatar
    9th December 2014
    811
    It will still need tech2 activating after fitting, If your in the North West or near i know a man who can do it for you.......
    Astra H OPC - CDTi Conversion with K&N Panel Filter | Iridium NGK Plugs | Custom Rocker Cover | Various Orange hoses | CD70 / CID upgrade | Interior LEDs | BMW Mini Sport Aerial | Insignia Washers | Courtenay High Flow Plenum | Hekos | MWP S1 Remap
