Results 1 to 6 of 6
Thread: E85 or Flexfuel
    10th August 2017
    64
    Default E85 or Flexfuel
    Anyone had tried or researched into making a flexfuel tune/setup?
    Made my own (approx) E20 Mix over the weekend with a blend of E85 and 98 octane.
    Car runs so much nicer no more hesitation at low end (and the high end for that matter).
    I know GM is E10 certified on this car, but I wonder if theres any capacity for a E85 or flex fuel tune on this thing?
    ^^Australian^^
    19th January 2014
    1,842
    We don't have access to E85 in Ireland/UK since 2012.
    Our governments gave us incentives to buy flex fuel vehicles and then took it all away by taxing E85 fuel to the point that it wasn't worth buying, so the suppliers have discontinued it and fuels are now about 5% ethanol.
    It's recommended not to go above E15 without tuning/conversion kit. Keep in mind that the 98 octane may already contain a certain percentage of ethanol when calculating the total ethanol content of your blend. I used to blend it up to E15 when I had a Mivec Lancer that had a preference for 100 RON.
    There are kits readily available such as;
    https://www.ebay.com/itm/Ford-XR6-Tu...5Yns0L&vxp=mtr
    but you'll need to be very careful to check which are compatible with your fueling system method and injector type
    OPC ÉIRE
    11th July 2017
    319
    i tbought all UK fuel was e5 these days... i have run mine on home made e10 and does go well once the ecu adapts
    19th January 2014
    1,842
    It is as you've said; E5 (approx) where petrol is concerned.
    OPC ÉIRE
    10th August 2017
    64
    Here in Australia we have:
    E10: 94.5 octane
    91 octane (no ethanol)
    95 octane (no ethanol)
    98 Octane (no ethanol)
    E85: 105 octane
    ^^Australian^^
    19th January 2014
    1,842
    In Ireland we have; 95 octane (E5)..... and that's about it.
    Anyways, I use LPG. 110 RON.
    OPC ÉIRE
