Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    VXRed Vxr..'s Avatar
    1st March 2018
    190
    Default Help with my exhaust
    Can any tell me if this is a standard exhaust
    I think
    Sorry for bad pics it’s too low to get under and no access to a jack at the min.
    I ask this because cat is blowing and I want to replace it ASAP.
    20th March 2015
    360
    Looks standard, but should just be the flexi joint that needs replacing looking at the 3rd pic
    1st March 2018
    190
    Thanks. Is that a easy change has in the 2nd pic there’s nothing to un bolt
    Also if I was to order a sports cat what’s the standard size
    20th March 2015
    360
    Not sure on the Astra but may be a cut and weld job unless it’s cheaper to get a new downpipe.
    Think the Astra is 3” but again not 100%
    1st March 2018
    190
    Ah so it the down pipe I need to be looking at
    I’ll price one up saves messing about
    18,147
    It's definitely a standard pre cat anyway.
    1st March 2018
    190
    If I was to get a de cat down pipe would it put eml on and join up to the standard exhaust
    18,147
    There's plenty of pre cat decats for oe systems. And there shouldn't be an eml issue as long as the main cat is in place.
    1st March 2018
    190
    Would this fit
    15th May 2013
    17,929
    Quote Originally Posted by Vxr.. View Post
    Would this fit
    Yep. That's what I referred to earlier in the thread
