Results 1 to 7 of 7
    VXRed danlee's Avatar
    30th March 2013
    21
    Default Engine Light. Code: P0110-14
    Hi people,
    Engline light just came on and plugged in laptop with ***** software. Giving me a P0110-14 / Intake Air Temperature Sensor Circuit High Input.
    Can anyone shed any light on this? Anyone had this before?
    Any help would be appreciated!
    Thanks,
    Dan.
    Are you VXR enough? kopite81's Avatar
    9th December 2014
    811
    What do you get on the pedal test?
    Astra H OPC - CDTi Conversion with K&N Panel Filter | Iridium NGK Plugs | Custom Rocker Cover | Various Orange hoses | CD70 / CID upgrade | Interior LEDs | BMW Mini Sport Aerial | Insignia Washers | Courtenay High Flow Plenum | Hekos | MWP S1 Remap
    30th March 2013
    21
    Hi mate, on the pedal test I get ECN 011014.
    9th December 2014
    811
    Do you have a dump valve?
    30th March 2013
    21
    Nope. I am getting a buzzing noise coming from my exhaust at the moment, had this issue before with the exhaust and my flexi is coming apart. Maybe something to do with it?
    9th December 2014
    811
    Check this out
    http://www.vxronline.co.uk/forum/sho...ck-error-codes
    The first 4 digits indicate the fault, the last 2 digits contain a value.
    For example: ECN 161450: problem with communication between immobiliser and key-transponder.
    9th December 2014
    811
    P0110 intake sensor signal is too large C-008
    P0110 intake sensor signal to small C-008
    P0110 Ansauglufttemperaturfühler error
    P0110 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
    Its gonna be related to one of them.....
