Results 1 to 10 of 18
    25th October 2017
    78
    Default Astra h vxr engine management light
    My car keeps cming up with the engine management light .
    I have had the coilpack replaced and all the plugs.
    The codes that come up.
    Is 10001 and 10401 which if i am right is misfire on cyl 1 and 4.
    Any ideas. It's got a warranty so it's going back in to be looked at.
    It seems to do it when its been running 10 min . And I go to 4000rpm.
    Sent from my SM-G930F using Tapatalk
    18,188
    What coil pack and plugs were used mate?
    15th May 2013
    17,935
    Same question here...
    Genuine GM plugs and Bosch Coilpack?
    VXR enough andrewt1971's Avatar
    25th January 2010
    3,390
    Are those codes correct? 100 and 104 are maf codes iirc, missfire would be 301 and 304.
    18,188
    I was thinking maf too.
    What filter is on the car?
    25th October 2017
    78
    Hi sorry for not getting back . Don't get notifications!!
    But after going back to garage they replaced all plugs and Bosch coilpack.
    And this morning still doing it!
    It's the code for misfire on cyl 4
    They even switched injector from cyl 4 to 3 to see if code moved but still saying cyl 4
    It's original filter.
    Dan
    18th February 2007
    51,676
    Quote Originally Posted by Danjamesvxr View Post
    Dan
    Change settings here - http://www.vxronline.co.uk/forum/pro...do=editoptions
    Look for Default Thread Subscription Mode to help with notifications
    Astra
    25th October 2017
    78
    Hello again..back with another problem .. w20adm lookin to pick your brains again.
    My keyless entry start button playing up. And I get a padlock on the dash when pressing the button.
    I have changed both batteries.
    And have disconnected the battery as heard that resets the modules. But still nothing.
    It sometimes decides to start. But it's either key or even both keys so it's not the keys that's the issue.
    But then I'll try again 2 min later and nothing.
    I rang the garage and he said it's a peeps system or something. And he said it sounds like a receiver has gone down.. And gunna be expensive does this sound about right ? Thanks
    Sent from my SM-G960F using Tapatalk
    18,188
    Could be a knackered peps door sensor yes mate.
    But before you look at that what battery did you use? As daft as it sounds if you try a duracell battery it's a bit chunkier and sits in the hole a lot more snug. It totally cured the issue on mine when I had same thing, intermittent working of the key fob and padlock on dash.
    25th October 2017
    78
    Well I have used an energizer in one and a Maxwell in the other they both unlock doors and stuff. And occasionally they will turn dash on then start car. But then they won't. At this moment my car is pretty much us less on my drive
