Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 42
Thread: AFL Retrofit
  1. #11
    VXR enough Markpvxr's Avatar
    10th July 2012
    1,156
    Fit the afls yourself etc and ask vaux to activate the lights... It takes 2 minutes. Pecky might be worth an email... I fitted mine on his driveway and it took him 2 minutes to turn on
    Arden Astra with black bits
    Engine Originally built by wg motorworks blew up after 34 mile so Muni Singh had to sort out his mess 👍🏻
  2. #12
    VXRed MbrownVXR08's Avatar
    10th October 2016
    187
    Quote Originally Posted by Markpvxr View Post
    Are they full afl or bi-xenons bud?
  3. #13
    VXR enough Jon1796's Avatar
    24th August 2015
    1,521
    Default AFL Retrofit
    I’m in Norwich what you got to do as I’ve t2!
  4. #14
    10th October 2016
    187
    I need to fit the afl set up and activate it in simple terms
  5. #15
    24th August 2015
    1,521
    Just changing over the lights or do you need wiring done as well , as I’ll help fit and switch on but try jccars for wiring or he’ll probably do it all if your close to wroxham.
  6. #16
    24th August 2015
    1,521
    How far from Norwich are you ?
    Have you got the self levelling switch’s front/rear or has that got to go on ?
  7. #17
    10th October 2016
    187
    Need to do the wiring however going to buy the plug and play looms. There is still a bit of wiring to do with them to the control box behind dash etc so I will give the chap a ring cheers
  8. #18
    10th October 2016
    187
    I’m near Harleston so 20 miles. I have got all the parts apart from looms ready to go on so the full set up to be fitted
  9. #19
    10th October 2016
    187
    Also have the headlight washers to fit
  10. #20
    24th August 2015
    1,521
    Just had a look on Pecky’s site yeah you’ve got a bit of wiring to do.
    If you want a hand fitting the other parts not a problem to lower the bill.
