Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 33
  1. #21
    VXRed blooded Seanwebb68's Avatar
    31st July 2014
    393
    Or you could just get ones from https://www.eurocarparts.com/brake-discs
    Tuned By Rabbid Remaps
  2. #22
    VXRacing ahead tye_time's Avatar
    24th February 2017
    609
    Yeah i would rather stick with GM or OEM - I will need new pads before discs anyway.
  3. #23
    VXR enough Matt1982's Avatar
    19th June 2016
    1,361
    Quote Originally Posted by Seanwebb68 View Post
    Check here
    http://www.vxronline.co.uk/forum/sho...1-Part-numbers
    Front Brake Pads: 93186003
    Front Brake Discs: 93185817
    Rear Brake Pads: 93188727
    Rear Brake Discs: 93184247
    Nice one fella
  4. #24
    19th June 2016
    1,361
    Anyone know what size the little bolt that holds the disc is??
  5. #25
    17,580
    Check here
    This is good. Never knew this was here.
  6. #26
    25th September 2013
    1,078
    I have the ebc yellow and grooved discs and always been ok for the car but will try the Ferodo DS2500 next time.
    stage 3
  7. #27
    VXR enough X8 DUD's Avatar
    26th October 2012
    2,735
    The Ds2500 far better than EBC's, but are a lot more expensive so depends whether you actually have the need for them
  8. #28
    26th February 2012
    1,772
    Quote Originally Posted by Matt1982 View Post
    11093893 is the p/n. says its m6
    http://www.vauxhallsuperstore.co.uk/...rsunk_11093893
  9. #29
    19th June 2016
    1,361
    Quote Originally Posted by hairyoscar6 View Post
    Cheers fella how's your Astra??
  10. #30
    26th February 2012
    1,772
    Still putting a smile on my face, regurally in Biddulph but never see you about
