Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 78
  1. #21
    17,613
    I'm convinced to try it myself. Just need my hazard switch cluster, door windows switch module, heater controls and cd70 doing. Rest are already blue.
  2. #22
    9th January 2017
    822
    Gave this a go yesterday but I had to give up. Everything is so tiny it's unreal, the actual smd led's are only about 5mm x 5mm in size and the one's I need to change are the 4 contact one's which makes things even more difficult as each solder point is around 1mm wide. I didn't have any way of magnification, the soldering iron I borrowed was wayyy too big for the job and the solder I had was also too thick.
    Silver Lightning Corsa VXR
  3. #23
    17,613
    I'm trying to get the exact smd's I need from that crazy leds site but it's becoming a right ballache. Specified what I want but just keep getting mish mashed replies as to what I actually need ......
  4. #24
    9th January 2017
    822
    Have you looked in the vehicle specific section to see if the one's you need come in a kit.
    These are what's needed for a corsa so I'm presuming the astra would be similar.
  5. #25
    17,613
    Quote Originally Posted by iamphil View Post
    Managed to get my order together yes. Only need them for cd70, windows switch drivers side, hazard rail and heater panel.
  6. #26
    9th January 2017
    822
    I hope you are good at micro soldering, I'm not 😊.
  7. #27
    17,613
    I forsee a lot of cursing and swearing coming my way .....
  8. #28
    9th January 2017
    822
    Yep 😄 make sure you have a magnifying glass of some kind and the tip of your soldering iron is only around 0.5mm - 1mm wide as the contacts are tiny. I was contemplating trying out solder paste where you can apply it wet then heat it up using one of those heat stations while holding the led's down with tweezers.
  9. #29
    17,613
    I always get myself into this crap
  10. #30
    17,613
    Man these are teeny!!!!
