Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Vacuum at idle
    VXR enough R34nel's Avatar
    17th May 2009
    2,549
    Default Vacuum at idle
    Can someone with a boost guage tell me what vacuum your car shows at idle, with the air con off.
    Iím fixing a brake servo leak and this is the only way I can be sure itís fixed, I just donít know what the vac should be.
    Stage 3 Arden Astra gone
    Stage 2 burg
    VXR enough andrewt1971's Avatar
    25th January 2010
    3,325
    Just pop the brake servo pipe off the manifold and get a helper to block the nipple with a finger and see if your reading changed, eliminates any inaccuracies in different gauges.
    17th May 2009
    2,549
    Yeah good idea thanks
    Stage 2 burg
    17th May 2009
    2,549
    I tried this and it sits at -10
    I had read someone saying it should be higher than that so can someone let me know what’s theirs shows approx?
    Just want to confirm that there are no other leaks
    Stage 2 burg
    17,613
    It should hover right around -20 mate
    Whenever mine has said higher I had a boost pipe popped off
    17th May 2009
    2,549
    -20 you sure?
    even going down hill on a low gear I don’t see any lower than -14.
    It is unchanged from before I fitted the cooler, so I’m confident a pipe hasn’t come off because I’ve changed it all and it reads the same
    Stage 2 burg
    17th May 2009
    2,549
    Is that psi that yours reads?
    Stage 2 burg
    17,613
    Yes mate. And yes -20 psi.
    17th May 2009
    2,549
    That’s bizzare, I’d expect a leak so big to cause it to idle like crap but it doesn’t, if I take off a vac hose it goes really lumpy like it will stall.
    can someone else looks what theirs reads to confirm?
    Stage 2 burg
    17,613
    Mine when letting off throttle will shoot right down to below -25ish. Always has done. And sits at -20. Like I've said, the 1 or 2 times it hovered at -10 I had a boost leak from somewhere.
