Results 11 to 20 of 25
Thread: Vacuum at idle
  1. #11
    VXR enough R34nel's Avatar
    17th May 2009
    2,548
    I see, defo doesn’t sound right then
    Stage 3 Arden Astra gone
    Stage 2 burg
  2. #12
    22nd September 2016
    125
    Mine sits at -23 at idle, my gauge measures the negative pressure in in hg though. Works out at about -12 psi if you convert it
  3. #13
    17th May 2009
    2,548
    Quote Originally Posted by DanMc View Post
    That’s interesting, that’s what I was lead to believe it should be but Adams reading had me concerned.
    Now I don’t know what to think!
    Thanks for the reply mate.
    Adam do you think it’s possible your negative readings are the same? I just can’t see how I could have such a large leak but still see 10-12 psi on boost (stock map)
    Stage 2 burg
  4. #14
    17,580
    No mate definitely not. I guess my car is the only one running properly
  5. #15
    17,580
    Btw is this idle warmed up or idle from cold on increased idle? ....
  6. #16
    17th May 2009
    2,548
    Stage 2 burg
  7. #17
    17,580
    Told ya -20 was right
  8. #18
    17th May 2009
    2,548
    Did you read it all?
    Andy was saying that -20 psi isn’t possible due to some science I didn’t understand and if a guage reads that it’s measuring in Hg, a guage which reads minus in psi will show -10 which is what mine is reading
    Stage 2 burg
  9. #19
    17th May 2009
    2,548
    He said the max vacuum is -14.7 psi, the max I see on mine is 14 although it only reads whole numbers
    Stage 2 burg
  10. #20
    17,580
    Sorry forgot to say my minus is in hg. It should all be hg. There's no such thing as minus psi pressure
