Results 1 to 3 of 3
Thread: Bonnet sensors
    26th November 2017
    19
    Default Bonnet sensors
    Anyone had issues with bonnet open warning coming up on dash ? Starting to do it more and itís getting to me now
    VXRed ALEX-E92's Avatar
    20th May 2017
    36
    Hi Sam, this is a common issue. To fix the issue you can either take it to a dealership which some people do. Or you can do what I did to save the time, I just glued a plastic washer to the top of the bonnet sensor to shorten the amount of play in the compression of the spring when the bonnet is shut. Simply fixed and still no issues a year later 😁
    My bonnet sensor error use to come up on the instrument panel whenever I went over a bump in the road or sometimes even just turning on the ignition switch first thing.
    26th November 2017
    19
    Quote Originally Posted by ALEX-E92 View Post
    Cheers bud! Yeah thatís what mines doing over bumpy road surface 😩 think Iíll do it myself, havenít got time to leave it at the dealers 😂
