Results 1 to 9 of 9
    15th February 2018
    7
    Default A couple of plugs and vacuum pipe!!
    Afternoon all. Any help on where these go...
    9th January 2018
    120
    I don't think that sensor in the same picture as the vacuum pipe goes anywhere mate I think that sensor is designed for the Diesel VXD
    15th February 2018
    7
    Ahhh okay man. Any ideas with the vacuum pipe?
    9th January 2018
    120
    Quote Originally Posted by Joevxr90 View Post
    Not 100% sure mate but check on youtube about the Vac Box issue...this could be a pipe from the vacuum box behind the engine
    15th February 2018
    7
    Yea man it comes from that box and runs up the back of the block. Was all connected until I dropped the engine in and now it’s popped off and I can’t remember where it was!
    15th February 2018
    7
    Anyone!? Does nobody own an Astra H VXR they can go and look on the side of the inlet and tell me!?
    22nd April 2017
    72
    Why don’t you just look for any obvious places it could go
    VXRacing ahead
    23rd February 2015
    602
    Front multiplug looks like airbag crash sensor that goes under front slam panel where bonnet latch is.
    Vac lines chase them and should see the location
    Sent from my SM-G935F using Tapatalk
    15th February 2018
    7
    Thanks Knight vxr the vacuum was from the recirc valve.
    Carlmu wow I hadn’t thought of that!! ��
