Results 1 to 7 of 7
    25th April 2018
    10
    Default Clutch biting point
    Hi all.
    Had my VXR a month roughly now and noticed my biting point is right right right at the top of the pedal, however the clutch doesn’t slip at all and engages all gears perfectly. Even 4th gear plant it no slip at all?! Any way I can sort this? Drives me mad!
    11th July 2017
    294
    clutch slave or master may be wearing out or need bled.
    any tightness changing gears.. could just be getting enough pressure to release the pressure plate but only just.
    try bleeding the system
    25th April 2018
    10
    No the gears feel fine, sometimes I feel they’re a little notchy but 99% of the time is okay, bleeding thebsystem how is this done on the VXR?
    11th July 2017
    294
    the bleed nipple is on the top front edge of the gearbox...just follow the hose but its a little difficult to get at and may need complete removal of the battery and its plastic box
    25th April 2018
    10
    That’s not too much of an issue. I presume an EzeeBleed kit can be used? Worth flushing/changing the brake fluid at the same time too? And bleeding brakes through also
    11th July 2017
    294
    Quote Originally Posted by JaamesVXR View Post
    theres no harm in doing it all anyway...easibleed work ok , just be sure to operate the pedals at some point to clean out any old fluid / air in the master cylinders.
    even if it doesn't resolve your problem its routine maintenance that usually gets ignored as most think its a big costly job.
    25th April 2018
    10
    Yes exactly. I have an electronic brake fluid tester. Will check the condition of the fluid to see if it’s beenchanged (very much doubt it!)
