Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    23rd May 2013
    2,413
    Default Doing Gearbox Bearings in Situ?
    Hi,
    I think my gearbox bearing are starting to play up.
    No gearstick play but there seems to be a whining in 2nd and 3rd, also a clunk going into gear sometimes from neutral
    Its on 42k.
    I've read that some of the bearings (6th) can be done in situ...has anyone done this or can offer a rough guide?
    15th May 2013
    17,909
    Hi,
    Its on 42k.
    I can be done buy the pros in situ. You planning on doing yourself then?
    23rd May 2013
    2,413
    Yeah, but just the 6th gear one as it seems to be the common one.
    If it needs any of the others i'd take the box out and drop it off somewhere.
    11th January 2006
    2,268
    support engine
    remove gearbox mount
    remover the mount of the top of the gearbox
    drain oil
    lower box slightly
    undo all trox bolts holding casing on
    tap casing to break the seal then after lowing box some more slide it out
    push selector shafts back into box as they can come out with casing
    remove circlip pull off bearing
    fit new bearing
    clean out end casing remove old bearing casing refit new one
    best to change all 3 bearings whilst you are there
    clean off sealant of casing reapply some new
    refit casing
    top up fluid
    can buy a 3 piece bearing kit off ebay for around £55 hth
    23rd May 2013
    2,413
    Thank you, thats spot on.
    I will have a look at the bearings on ebay as well.
    23rd May 2013
    2,413
    Got the 3 bearing set for £39 quid. Thanks again
    23rd May 2013
    2,413
    BTW is the any torque values for the end case?
    Assume as its got sealant it'll be fairly low like doing a sump so ~12 Nm
    23rd May 2013
    2,413
    Update on this;
    I have attempted to do this today and have got most of the way there...i've got the end case off without any real problem and have managed to pull off the 6th gear (i think) bearing so far .
    Problem is getting the new bearing on...i've got it flush with the end of the shaft but cant get it pushed any further than that to get the circip back on
    I've read on the fiat forum that some guy used his puller to push the bearing back on so i'm guessing i have the wrong puller? Mine is just a 3 claw one so i'm guessing the one that guy used perhaps screwed to the bellhousing and could be used as a pusher.
    Obviously now i'm going to have to go buy the tool...can any suggest which one to get?
    I don't want to try a BFH on the new bearing in case i damage it.
    Help appreciated.
    23rd May 2013
    2,413
    Some pics in the meantime
    23rd May 2013
    2,413
    Moar;
