Results 1 to 6 of 6
Thread: PCV valve
    27th March 2017
    12
    Default PCV valve
    Hi, can anyone tell me where i can locate the pcv valve on a Corsa D VXR Z16LER?
    27th March 2017
    12
    Thanks for the reply Shaun_ml7*.
    27th March 2017
    12
    I had a look at the link to see where the valve can be located and the inlet manifold looks different to the one fitted on my Corsa D VXR. Is the pcv valve located in the induction manifold or exhaust manifold? I believe it is in the induction and not the exhaust manifold but in case, I have a dbilas exhaust fitted.
    Does the Corsa D VXR have a PCV valve?
    The induction manifold i have is OE / OEM Number: 55564546/55355607.
    Link to see the manifold fitted on my Corsa D VXR
    https://www.ebay.es/itm/VAUXHALL-COR...-/322541605390
    23rd May 2013
    2,059
    Pretty sure it doesn't have a valve as such.
    Theres just a breather pipe coming off the camcover to vent fumes back into the turbo inlet.
    27th March 2017
    12
    Appreciate your reply. After a rigorous search my conclusion is too that it does not have a pcv valve.
