Results 1 to 10 of 11
Thread: Help
    25th April 2018
    23
    Default Help
    Hello guy n gals, I need some help please. My Astra VXRacing isn't running well, not holding boost and stuttering when put foot down. I would like to try a coil pack ASAP. Does anyone have either a spare I can try or be willing to let me try theirs to hopefully identify the problem.
    Thank you in advance
    Ian
    18th September 2017
    480
    Where are you
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
    25th April 2018
    23
    I'm in North Shields...
    I got one last night but it's made no difference. Looking at possible fuel pump/boost solenoid/recirc replacements now
    AFM graph is all over when car comes on boost (full throttle) she splutters and doesn't make full torque (150NM less than should be) and then runs lean on rest of power run.
    18th September 2017
    480
    Could be a possible map sensor
    25th April 2018
    23
    Hmmmm...
    18th September 2017
    480
    If the map sensor is faulty you wouldn’t get full power and it would mess with fuel air ratios as it’s the sensor leading to throttle body
    25th April 2018
    23
    Would it cause misfire though?
    15th May 2013
    17,882
    Default Help
    How about spark plugs? When were they last done?
    Worth checking all your boost hoses the lot too
    25th April 2018
    23
    Plugs are new - bought a coil pack from a member on a Facebook group (but it made no difference so it could be a dud?) - i do keep popping a hose off, get the turkey warble...
    Installed a Courtenay boost gauge last night and runs at -30 at idle (-15 when hose pops off) but when boosting doesn't seem to pass +10 - is that right? Car is Courtenay Stage 2
    15th May 2013
    17,882
    I would try another coil pack mate.
    A fella I know had the same issue recently and was the coilpck
