Results 1 to 10 of 12
Thread: Any suggestions
    VXR enough Matt1982's Avatar
    19th June 2016
    1,365
    Default Any suggestions
    Hey Folks
    Just wondering if anyone has a suggestion to remove this I've used my usual wheel cleaner and also a fallout iron remover
    Thanks for any help
    18,147
    Man! That's a mess. You tried bilt hamber autowheel?
    19th June 2016
    1,365
    Sure is a mess had a sticking caliper not tried that tempted get some though to see if it will do anything
    18,147
    If you've tried a fallout remover though I don't know why it hasn't shifted it ..... what did you use? You didnt let it dry did you?
    VXRed VXR-Carlos's Avatar
    13th May 2017
    54
    CarPro iron-x is really good for breaking down the bond between the oxidation and the surface, that or as above the bilt Humber is also highly recommended
    18,147
    Autowheel is by far the best wheel cleaner I've seen, and I've seen quite a few. It just puzzles me if he's tried a fallout remover and its done nothing, what could it be :/ ....
    15th May 2013
    17,929
    If nowt else does it Matt. Take it down a powdercoaters 😂
    18,147
    Acid bath ftw.
    13th May 2017
    54
    It’s certainly the worst wheel I’ve seen in all my years of valeting. Only thing I can think of is that most wheel cleaners are pretty weak in retrospect of them not been acidic. I’d be thinking of trying an acid based cleaner or just run with them as they are till can be refurbed.
    18,147
    It actually looks like surface corrosion.
