Results 1 to 4 of 4
Thread: Door respray
    22nd September 2016
    126
    Default Door respray
    Have noticed the passenger door is a different shade of black to the rest of the car, guessing it’s a bad respray done by a previous owner.
    Any ideas on a reasonable amount I should expect to pay for a decent respray? Also is black sapphire an easy colour to match?
    18,147
    A good bonnet respray non mates rates would be circa 200. So probably a tad less than that.
    VXR enough X8 DUD's Avatar
    26th October 2012
    2,738
    My old astra was black sapphire and had to have one side sprayed, depends on who does it, had mine redone 3 times before it looked how it should. First time just came back as flat black, looked like two different cars lol
    6th February 2008
    15,982
    Black is one of the worst colours to spray , you will also probably find the panels around the door will need spraying to fade the colour in
    Best solution, go and get some quotes - as you will find it will vary from one place to another
