Results 1 to 8 of 8
Thread: Afl fault
    VXR enough yodacraig's Avatar
    25th January 2010
    3,085
    Default Afl fault
    Alright chaps after a bit of advice my afl fault light has came on when I turn the car off and on it goes off but when I turn the lights on and drive for about a minute the driver side headlight flickers then the light comes on I have tried changing the bulbs which hasnít solved the issue anyone got any ideas is there something conman that fails on them??
    Craig
    xbox addy -turboyoda85
    Instagram yoda_craig85
    VXR enough Markpvxr's Avatar
    10th July 2012
    1,157
    resistor/ballast issue by the sounds
    Arden Astra with black bits
    Engine Originally built by wg motorworks blew up after 34 mile so Muni Singh had to sort out his mess 👍🏻
    25th January 2010
    3,085
    Any idea where I can pick new ones up ??
    VXR enough Minismithy90's Avatar
    28th July 2010
    1,826
    Control Module ? One of my AFLís failed last year, turned out one of the Wires that connects to the bulb/holder had snapped, in which resulted in a complete new AFL Headlight.
    So have a good look around.
    Fiesta Mk5 ZS>Fiesta Mk6 ST>Clio 172>Astra 'H' VXR>Fiesta Mk7 ST>Corsa 'D' VXR Nurburgring
    25th January 2010
    3,085
    Plugged in to my mates laptop came up left curve light stuck right curve light stuck any ideas ??
    25th January 2010
    3,085
    Worst case scenario where could I get a new afl unit without having my pants pulled down lol
    6th May 2017
    809
    I think you're better trying eBay or a breakers. New ones are a good few hundred, I think.
    28th July 2010
    1,826
    Default Afl fault
    I bought mine from Eurowagens £260 itís a Valeo part.
    Have you tried a Voltmeter on it ?
    Faulty AFL light 😞
    https://r.tapatalk.com/shareLink?sha...1&share_type=t
