Results 1 to 10 of 13
Thread: Had it now.
    VXR enough V6spike's Avatar
    18th May 2013
    1,833
    Default Had it now.
    If itís not one thing itís another. Sorted my P0234 code by removing the map and replacing it with a hybrid from Steve @dog_book.
    Now have others.
    So hacked off now. Donít mind spending money on routine maintenance stuff but this is getting beyond a joke.
    I donít know what to do.
    VXRed jasez28net's Avatar
    29th July 2011
    89
    Sorry to hear of your continued problems mate. Hope you get it sorted soon. I took my Siggy into my local VX dealership this week to sort my aircon that wasnt working. It just needed a re-charge. Found out i needed new front discs and pads and my tyres had seen better days. Replaced all 4 tyres (P Zero) and got my wheels refurbed at the same time (diamond cut). 2 grand gone in the blink of an eye!
    My Vauxhall history - 92 Cavalier GSI 2000 4x4, 99 Vectra B GSI, 04 Vectra C GSI, 08 Vectra VXR, 15 Insignia VXR
    VXR enough Jon1796's Avatar
    24th August 2015
    1,535
    When did this start after map ?
    24th August 2015
    1,535
    Mid speed canbus not set would kick off a lot off these as its saying not programmed ?
    24th August 2015
    1,535
    Your gonna have to check all mid speed setting in all modules and reset and programme in.
    18th May 2013
    1,833
    Jon. No idea how to do that. I tried clearing codes but my ***** wouldnít for some reason.
    To be honest all those codes (less the BAR) only came to light when I did a dtc check on the modules.
    24th August 2015
    1,535
    Out shopping at mo Iíll pm ya when Iím home.
    Are you VXR enough?
    14th August 2013
    873
    Do you have a standard map you can go back to?
    1st August 2016
    400
    Quote Originally Posted by sinbrad View Post
    A faulty cim has nothing to do with the program within the ecu, nor a sensor not being plugged in properly
    Vectra VXR estate 07
    24th August 2015
    1,535
    Default Had it now.
    Right picís
    Immobiliser,cim,ehu,dis,uhp.........are mid can modules
    Just go through them if they wonít let you change or if no listings (present/not present) youíll probably need new module.
    I wouldnít worry about the last one as Iíve got it too.
    New cim and different cid no change.
    Is that easy enough to under stand.
