Results 1 to 10 of 11
    VXR Nothing comes close Tom_Y2K4's Avatar
    3rd August 2009
    24,555
    Default Corsa 'burg - Brake Pads/Discs?
    Best place and price? Did we ever establish if they were the same as Megane 225?
    South East Regional Organiser
    PSN: TomFL12
    23rd May 2013
    2,461
    Discs wouldn't be as reno is a different pcd and bore
    VXR enough Minismithy90's Avatar
    28th July 2010
    1,826
    Try Brakes International. Got my Discs from there, they Apec, but they do the job. Not 100% Sure on Pads though.
    Fiesta Mk5 ZS>Fiesta Mk6 ST>Clio 172>Astra 'H' VXR>Fiesta Mk7 ST>Corsa 'D' VXR Nurburgring
    23rd May 2013
    2,461
    They'll most likely be robbed off some other Fiat/Alfa given that the Corsa shares the same platform.
    After a quick search the Alfa 159 1.9 JTDM is same PCD and centre bore as VX and comes in 305mm x 28mm
    Might be starting point?
    3rd August 2009
    24,555
    Think pads were the same as the 225 setup?
    Will have a look around for discs
    PSN: TomFL12
    VXRed Taurus's Avatar
    18th June 2012
    196
    Tom,
    I got new front discs and pads from Courtney's, cheaper at time than local main dealer, and got HP2000 material they are good but do squeak a bit at times, I also had to buy new retaining pins as getting the old ones out was a nightmare need big hammer and correct size pin punch
    C0RSA VXR NURBURGRING #220
    18th June 2012
    196
    The pads supplied by Courtneys were Brembo part number 07.B314.21 for Renault Megane RS/ Alfa Mito, they had wear sensor wire/connector but as burgs don't just cut off at friction material with side cutters
    18th June 2012
    196
    18th June 2012
    196
    Courtneys £160 discs £139 HP2000 pads
    3rd August 2009
    24,555
    Top man, cheers.
    Think i've got a few months left on mine (it doesn't get used) but will need them for the next service/mot in March without doubt
    PSN: TomFL12
