Results 1 to 4 of 4
Thread: Drain Hole?
    Are you VXR enough?
    14th August 2013
    802
    Default Drain Hole?
    Ok guys, was parked on a slight incline this afternoon and when I went back to the car I noticed a puddle of water coming from under the car. After testing it, it seemed as it was water and not coolant or windy wash. So when I got home I put the car up on the jack and had a look underneath to see where the water was coming from. There seems to be a short rubber hose that looks like it is coming from the rear bulkhead and it's tucked up behind the exhaust downpipe. It only protrudes a couple of inches but it's defo water that's coming out. Anyone any idea where the source of this pipe is?
    26th February 2012
    1,756
    aircon drain?
    25th August 2017
    93
    As above, sounds like the air con drain. Nothing to worry about. I panicked first time I saw a puddle of water under the car too.
    Are you VXR enough?
    14th August 2013
    802
    That's good news, like you I had a wee panic. Just never noticed it before
