Results 1 to 6 of 6
    9th January 2018
    69
    Default Oil Temperature Gauge Install - Help!
    Morning all, I've just purchased a oil temperature gauge from ebay. But I don't know how to set this gauge up. Does anyone live local to Bromley who could possibly give me a hand?
    VXR enough Markpvxr's Avatar
    10th July 2012
    1,122
    You need an oil banjo drilled and tapped to put your sender in, Then replace your existing bolt by the oil filter (oil pump bolt) It's the right hand side one you replace
    Arden Astra with black bits
    9th January 2018
    69
    The one I ordered comes with a oil temp sensor. Would I need to buy another part to fit this then (e.g banjo Bolt)
    10th July 2012
    1,122
    You will need to get your existing bolt drilled & tapped.. So either buy another bolt and get it done so you can swap straight over or get yours out then get someone to tap it 1/8th npt i think
    9th January 2018
    69
    10th July 2012
    1,122
    yeah
