Results 1 to 10 of 19
    9th January 2018
    121
    Default Boost issue - Help!
    Code 110611
    Keeps happening. This is stopping the car from having any boost what so ever. It hits a flat spot at 2.5k revs and donít pick up again what so ever. The boost gauge is reading 5 psi when this is happening. Itís also idling at -30 plus. I say plus cause itís off the dial
    VXR enough Markpvxr's Avatar
    10th July 2012
    1,157
    possibly maf sensor,
    Arden Astra with black bits
    Engine Originally built by wg motorworks blew up after 34 mile so Muni Singh had to sort out his mess 👍🏻
    10th July 2012
    1,157
    unplug it and go from there
    9th January 2018
    121
    Maf or map (intercooler boost pipe)
    10th July 2012
    1,157
    unplug maf and run without it, see if fault is there still
    VXRed blooded Rksmith's Avatar
    15th December 2016
    435
    Snapped actuator maybe just a stab
    VXRed Kawi Kris's Avatar
    20th April 2015
    51
    Vac pipe off probably, has it had the rear bcs delete?
    9th January 2018
    121
    I've changed the solenoid and it seems less frequent but it's still happening. I'll try cleaning the MAP sensor today and see how that does but me testing things can take days since it only messes up when it feels like it
    I'll check the rear vacuum box also, but no i haven't done a rear bcs delete
    3rd May 2015
    1,034
    Could be number of things a vac pipes come off on the back. a boost leak map,maf or solenoid but my guess would be the actuator itself remove the heat shield and See if it's snapped or stuck open if it's stuck open just give it tap from the bottom where the nuts are if it clicks back then bingo.
    Full 3" Piper turbo back, Airtec fmic, piper x cone, Dap r springs, tarrox g88 discs, EBC yellow pads, powerflex engine/gearbox inserts + rearbeam bushes, whiteline lower arms, vredstein ultrac vortis,courtnay retainers, turbosmart actuator + recirc. Courtnay sport stage 3 mapped.
    9th January 2018
    121
    Quote Originally Posted by godsgift View Post
    Thanks for the information mate!
    Will I actually see if the actuator is broken or not just by looking at it on the car or will I have to take it off the car to find out?
